Antec P182
3 Dec 2007
Essex
Hi All,
I purchased the below:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-070-AN
but the mirror one, and it was a B-Grade.
However, i am slightly confused regarding the different parts of the case. It didnt come with any instructions, and as i never built a PC before, i am a littl unsure.
I have the thing running, but because i have no instructiosn i'm finding it hard to mount the CD drive! :confused:
Where the hell do you mount it??
You need to attach the supplied runners which came with it, place them into the holes on the cd drive and then side it in from the front and they should just click into place.
Any Help with this?
Hmm, i'll try tonight, however, ipretty sure i put the runners either side of the drive and it looked way to big or small to fit in there, cant really remember. Either way it was one of those two options. I have a look.
Is there a manual comes with it?
You can mount the deive on three different places on the sliders, just work out which one you need for it to sit flush.
