Antec P182
Caporegime
4 Sep 2008
Yorkshire.
Hey, thinking of buying this case but I have a question.
How dusty does this get on the inside ?
Does it have dust filters ?
Currently in an Antec 300 and it stays fairly dust free, but can't stand cases that get dusty inside.
im looking to get myself this case as well mate, one thing i would really like to no is whats the cable managment like inside this case? my antec 300 is very tight would like to maybe run some power cable under the mo board
there is space between case side and mobo tray for running cables. The mobo tray has cut-outs as well for running the cables through.
cool that sound good to me, i want to put my 24 pin power connecter under the mo board but i can only seem to find a 20 pin extension cable do overclockers not stock a 24 pin extension?
Be sure to clean your dust filters regularly. It's a great case overall.
Btw, why you changing from a 300?
Im looking at getting one of these also. Love the stealth look.
Does anyone know if it will fit 2 4890s?
After removing upper HDD cage from motherboard compartment there's space for long graphics cards but it will be still cramped in there.
The cable from my PSU reached the plug on the board without needing any extra cables :)
