- 9 May 2009
Hi all
I am going to be getting this case and was woundering if u can replace the system fans that come with the case fo better air flow and less noise fan versions ?
If u can can u also use the controler on other fans ?
What do u think of the case for cooling and sound levels as I was going to go for a fractal design d2 case but decided this might be a better case.
Want a quiet case
Also going to be fitting a seasonic gold to this case does it have good air flow for the psu as I noticed the case does not have any cut out for the psu fan
and just one more question is this case designed to be like a hugh heatsink as I have read this case pulls heat away from the motherboard and harddrives never herd of a car doing that ?
Thanks on any help or info
Want a quiet case
