I've just built a system and I can't get the front panel audio connections to work. I'm using a Gigabyte Z68 UD3H motherboard which has the standard 10 pin HD audio connector on the motherboard. However the only sound I get is a buzzing sound (the exact same as if you were to connect the ring on a TRS connection) I've tried both the AC97 and HDA connection with no luck. The grounded sound doesn't not change when the system is powered down so I assume it must be a ground loop or a bad connection in the case wiring?
I have tested the motherboard connector with another case front panel audio connection and it works fine.
Any ideas?
Any ideas?
