Antec P193 - CPU cooler recommendation?
30 Jan 2011
What cooler would you recommend for the following:
Antec P193 case
P7P55D-E
i5-760
Currently rocking the Arctic Cooling Freezer 7, but was thinking about going up to the Noctua NH-D14 so I can OC the processor a bit further, but I'm not sure if it'll fit?
But other CPU cooler recommendations are welcome as well please, especially if you have one that does just as good a job, but is maybe 10mm shorter to be safe?
If there are any other P193 owners, please do chime in!
My NH-D14 fits nicely into my Antec P182. The 193 has roughly the same dimensions doesn't it? I reckon a monster Noctua will fit.
And if you want one of the best OC on air, I'd definitely recommend the D14.
