Antec P280 fan install
10 Sep 2014
I'm in the process of building my first PC and already hit a snag. The case is Antec P280 and I want to install two extra Antec true-quiet 120s onto the front intake. The included rubber plug things won't pull through the threads on the case (I snapped one and I dont want to try any more, I also dont want to drill the threads) so I'm happy to just screw the fans in but my question is, out of all the different screws that come with the case which ones (if any) are for fan installation? I watched a load of how-to videos and I know the screws I need for the motherboard etc but there a lot of them there that I don't have a clue what they're for. I could just install everything else and see what I have left over but I'd rather get the fans in first. I'm hoping this is easily answered and someone can help me so I can get cracking with this exciting diy project! Thanks
To start off, you can only use 2 screws per fan, one either corner.
In regards to the fans you are fitting, did they not come with screws? Should be 30mm long.
I've used Noiseblocker and Scythe fans, both of which come with screws. I also don't use the thread in the holes, as you can only tighten them so far. Find it best with the screws that come with a threaded washer. Got some new NBs to go in this weekend.
It is a great case for what it is, but I think they could have put a bit more thought into it.
I use a H100i, which fits in easily enough, provided it goes in first with the fans fitted. Then you have to put the mobo in and it is a tight fit, there is only a couple of mm clearance.
Thanks I figured it out, I pulled the rubber grommets through the opposite way from what the instructions say, and because the threads are sunken on one side the long rubber bit still snapped off but after I got it all the way through the fan and the case. So much hassle though, hope it's worth it..
I've got the P280 and I had the same issue installing my new fans the other week; Antec provide you with specific 'Antec' case fan screws. Download the cases manual from Antec and have a look :)
Enjoy the case, I'm loving mine!
