antec p280 & PSU unit
4 Dec 2011
hi guys
Thinking of getting one of these cases :cool:
What PSU would you guys say is best for the case to connect to a gaming rig setup as upgrading soon ?
And extra front fans to connect to the fan controller aswell needed !
Yep, given the Antec dual purchase discount, either a Truepower or HighCurrent (Gamer or Pro), exact model depends on intended rig power draw and whether or not modularity is required/wanted
Can't go wrong with apache blacks it seems
+2
Should get my P280 tomorrow, first thing to happen to it(after Chrimbo) is the Antec fans are getting ripped out.
2 Apache blacks going straight in the front(1 from my existing P-812 and another shiny new 1), I have another 2 on my 920 Khuler on push/pull going onto the exhaust.
***DO NOT FIT, Too Big***2 Thermalright TY-140 going in the top(1 from my existing P-812 and another shiny new 1).***DO NOT FIT, Too Big***
Apart from the khuler ones that's running very quiet on the Khuler software, the rest will be switched completely off unless gaming using a Nesteq FanMax 8-Channel Black Fan Controller.
Also have 2 6950>70's running very quietly on AC Extreme coolers too.
Edited to state that a pair of TY-140's don't fit in the top 2 mounts.
I have 2 Apache black inside and 2 Apache viper as fan intake. I used Corsair H100 for CPU colling in push config and so far, it managed to tame my 3930K @ 4.5 on low fan settings.
Just in-case the op has subscribed to his thread, just to let you know that I edited my above post to state that the TY-140's don't fit and you don't go out and buy any.
Now I need an extra Apache.
Thankfully I only bought 1, I was under the impression that if I rotated them they would fit but anyway I gave myself a good facepalm!
