- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
330mm x 260mm x 312mm (D x W x H)
Would the Palit Super jet stream 980 fit in this?
I was going to get a Fractal Arc Mini r2 (why don't you sell this?) but this Antec looks nice.
Just check that palit cards is 280mm. The P50 takes up to 300mm cards![]()
ah, my suggestion to you is look at CPU cooler height on cases, I assume GPU will be the same, we suggest max CPU cooler height is 130mm, your card is 133mm...
It depends on where it is measured from, base of card which sits in a port or from the top of the slot, which is above the port.
CPU sockets are raised, so the palit card may fit if the 130mm is from the base of the card, as the base of the card will sit around 5-8mm below the base of where a CUP cooler sits (hope this makes sense)
But I'm not making any promises![]()
