Antec Price Slashing!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
We have slashed the pricing on key Antec product :) Take a ganders, impressive pricing!
Antec P183 V3 Super Midi Tower Case - Gun Metal Black @ £99.98 inc VAT
The Antec P183 epitomizes cooling, quiet and sophistication. An Antec-exclusive three-layer side and front panel design (aluminum, plastic, aluminum) reduces noise and ensures Quiet Computing™. The P183 also boasts a dual chamber design that isolates the power supply from the rest of the components, minimizing heat and reducing system noise. Additional features include two internal 2.5" SSD bays, an external control for fans, cable management and a special gunmetal gray finish for one-of-a-kind style.
- Dual chamber design isolates heat and noise
- Power supply option: Comes with a power supply mounting adapter to mount either a standard size power supply or Antec's exclusive CP series power supply
- 4 x external 5.25"; 1 x 3.5"
- 6 x internal 3.5" for HDD
- 2 x internal 2.5" for SSDs
- 1 rear 120 mm TriCool™ fan
- 1 top 120 mm TriCool™ fan
- 2 front (optional) 120 mm fan for HDD
- Cable organizers behind motherboard tray minimize cable clutter
- CPU cutout allows for easy installation of CPU coolers
- Three-layer, sound-deadening side panels and front door (aluminum, plastic, aluminum) dampens noise and ensures Quiet Computing
- Double-hinged door opens to 270°
- 7 expansion slots
- Built-in washable air filters inside front panel
- Front ports
- 2 x USB 2.0
- 1 x USB 3.0
- Audio In and Out (HDA and AC'97 compatible)
- 0.8 mm cold rolled steel for durability; 1.0mm cold rolled steel around 4 x HDD area
- Motherboard: Mini-ITX, microATX, Standard ATX
- Unit Dimension: 514 mm (H) x 205 mm (W) x 507 mm (D)
Now Only £99.98 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £39.98 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for most of the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Now Only £39.98 inc VAT.
ORDER NOW
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black @ £82.98 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- No power supply included
Now Only £82.98 inc VAT.
ORDER NOW
Antec 1200 Twelve Hundred (V3 with USB3.0) Ultimate Gaming Case - Black @ £109.99 inc VAT
Antec's Twelve Hundred V3 gaming case combines maximum performance, cooling and compatibility in a full-tower package. Thirteen drive bays, space for graphics cards as large as 17.5", a CPU cutout, an internal 2.5" SSD drive mount and newly integrated USB 3.0 round off a robust foundation for your components. The Twelve Hundred V3 features a top Big Boy 200™ blue LED cooling fan, two rear blue LED 120 mm fans and three front blue LED 120 mm fans. Apart from standard size power supplies, the Twelve Hundred V3 can accommodate Antec's CPX form factor PSUs. Outfit your components and maximize their performance with Antec's Twelve Hundred V3.
- 13 drive bays
- External 3 x 5.25"; Internal 9 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 9 x 5.25"; Internal 3 x 3.5" for HDD or
- External 12 x 5.25 for HDD
- Internal 1 x bottom-mounted 2.5" SSD drive
- Convenient top accessory tray
- 2 rear 120 mm blue LED exhaust fan
- 1 top 200 mm Big Boy 200&tradel blue LED exhaust fan
- 3 front 120 mm blue LED intake fans with front speed control
- 1 window side panel 120 mm fan slot
- 1 middle 120 mm fan bracket
- 200 mm Radiator mount
- Perforated front bezel for enhanced air intake
- 7 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Maximum video card size: 17.5" / 444 mm (Note: some video cards may require removal of the adjacent hard drive cage)
- 2 x USB 2.0
- 1 x USB 3.0
- Audio In and Out (AC'97 and HDA compatible)
- Motherboard mount: Mini-ITX, microATX, Standard ATX
- Power supply mount: Standard size PSUs or Antec�s exclusive CPX form factor PSUs
Now Only £109.99 inc VAT.
ORDER NOW
Antec High Current Gamer 400W '80 Plus Bronze' Power Supply @ £37.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The
High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors
and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
Now Only £37.99 inc VAT.
ORDER NOW
Antec High Current Pro 850W Modular '80 Plus Gold' Power Supply @ £114.98 inc VAT
Antec's HCP-850 unifies raw power with advanced PSU engineering to meet the demands of high performing PCs. A full-featured, 80 PLUS® Gold-certified unit, the HCP-850 is capable of outputting 99 percent of its rated power on four +12V rails, ensuring CPU and graphics card compatibility. Exclusive to the High Current series, HCP-850 boasts High Current heavy-gauge 16 AWG wiring that boosts conductivity, increasing efficiency and improving power delivery. In addition, a double-layer PCB, onboard DC-to-DC converters and Active Power Factor Correction (PFC) provide substantial voltage stability. To tackle the needs of your system, pick up Antec's HCP-850.
- 850 watts of Continuous Power
- 80 PLUS™ Gold certified - up to 92% efficient
- NVIDIA® SLI®-Ready certified, ATI CrossFireX™ certified
- High Current Hybrid Cable Management utilizes a 10-pin modular connector system
- Special heavy-gauge 16 AWG High Current cable for CPU connectors boosts conductivity, increasing efficiency and improving power delivery
- 2 x 8-pin CPU connectors included for dual-CPU gaming, server applications and high-end motherboards
- Gold-plated high-current terminals for optimal conductivity
- 135 mm double ball bearing PWM fan for optimal and quiet cooling
- Four fully-protected High Current +12V rails ensure high-end CPU and graphics cards compatibility
- Up to 99% power available on +12V rails
- DC-to-DC voltage regulator modules ensure stability and higher efficiency
- Highest quality Japanese brand capacitors for long-term reliability
- Double-layer PCB allows for heavy-duty components
- ATX12V version 2.3 and EPS12V version 2.92 compliant
- Full suite of industrial grade protection: - Over current protection (OCP) - Over voltage protection (OVP) - Short circuit protection (SCP) - Over power protection (OPP) - Over temperature protection (OTP)
Only £114.98 inc VAT.
ORDER NOW
Antec High Current Pro 1200W Modular '80 Plus Gold' Power Supply @ £159.98 inc VAT
Antec's HCP-1200 unifies raw power with advanced PSU engineering to meet the demands of high performing PCs. A full-featured, 80 PLUS® Gold-certified unit, HCP-1200 is capable of outputting 99 percent of its rated power on its eight +12V rails, which contain high maximum loads to ensure graphics card compatibility. Exclusive to the High Current series, HCP-1200 boasts High Current heavy-gauge 16 AWG wiring that reduces conducted resistance, increasing efficiency and improving power delivery. In addition, a cool-running dual double-layer PCB and onboard DC to DC converters provide substantial voltage stability. To experience kilowatt-class power in an unmatched design, pick up Antec's HCP-1200.
- 1200 watts of Continuous Power
- NVIDIA® SLI®-Ready certified, ATI CrossFire™ certified
- High Current Hybrid Cable Management includes a 8-pin modular connector
- Special heavy-gauge 16 AWG High Current cable at CPU reduces conducted resistance, increasing efficiency and improving power delivery
- 2 x 8-pin CPU connectors included for dual-CPU gaming and server applications
- Quiet 80 mm double ball bearing PWM cooling fan
- Eight Fully-protected High Current +12V rails with high maximum loads assures graphics card compatibility
- Highest quality Japanese brand capacitors ensure long-term reliability
- Dual Double-layer PCB optimizes cooling efficiency and allows for heavy-duty components
- ATX12V version 2.3 and EPS version 2.92 compliant
- Full suite of industrial grade protection:OCP, OVP, SCP, OPP, OTP)
Only £159.98 inc VAT.
ORDER NOW
...I'm pretty sure I bought my 300 for that much a a few years ago.
The 183 would be nice with a dark interior with a nicer looking layout.
I used to think Antec cases were the bee's knees a few years back, they just don't seem as appealing compared to other offerings now though.
The cases look awsum but over the last couple of years they seem to be playing catchup compared to other cases at the same prices.
Nice prices was planning on getting the Antec's HCP-850 2moz :). perfect timing
The 300 was that price, but as everything, costs go up. But we still have the best price in all the land :)
