Antec problems
26 Apr 2009
Hi all, I have recently purchased an antec 1200 case, and the switech h20-220 water cooling kit.
With me being new to water cooling, It came to a shock of the size of the radiator unit in the kit.
The problem im now faced with is where do I attatch the radiator to my case? I dont want to block any of the case fans, or start tearing away my new case either with the cutter.
Any suggestions?
Thanks for reading and your advice.
I think the swifttech comes with an external radmount, so you could hang it off the back fan outside the case.
Hi Ewan, I believe it does come with a mount.......But wouldnt that reduce the air flow of the case fan, and if the radiator gathers dust, which Im sure it will, it would blow it into the case fan and start to clog the case fan with even more dust, right??? :confused:
Im assuming, the radiator and the case fan (at back) work at the same direction, being an innie rather than an outie, if ya know what I mean? lol.
I just didnt expect it to be soooo big, lol.
Anyways, thanks again for your advice and reading.
