- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi all.
I have just got back from Taipei, after a fun 10 days over there for Computex.
Here are a few of our highlights:
The P82 Crystal (name may change)
Next we have the Cube MAX
This is a v2 of the original Cube (and Razer Edition), we have upgraded the chassis to support mATX over just ITX. The perspex panels are now tinted tempered glass, the chassis has been updated with more vent mesh areas for heightened cooling, and the motherboard tray is removable using a slide out mechanism with a pull handle on the rear. Best of all the price is expected to be much more aggressive than the original models. Finally 120mm AND 140mm fan support now all around.
And now for the Striker! A fully open frame chassis based on the ITX motherboard with a cool twist
You want big? We have the Blazer GT concept.
This is a beast which can house so, so much. It can be set vertical or horizontal.
Glass panels on all sides, massive space for custom loops and crazy agressive design.
And finally the concept GTR
This case is totally different from anything seen before, it weighs about 30kg on its own and supports mATX and a full custom loop.
The pics say more than I can.
- Tempered Glass Front
- Tempered Glass Side
- Top Mount PSU with sexy Shroud
- Tri-radiator mounts in both side and base
- Vertical GPU mount with lots of space between GPU and TG side panel
- Removable PSU mount plate
- GPU fitment in the front of the chassis with an included pre-fitted riser cable
- Fully open frame
- Full watercooling system support
- 2 x 240mm radiator support
- Full ATX or SFX PSU compatible
- USB Type C
