theyre ok but you can get a lot better fans, i mean you could get a load of cheap 120mm and stick them on a £10 fan controller. itd be about the same price but you would have more control over the fans
They are not bad fans at all. And they are nice when they come free with the case. But i tend to replace the 120mm ones because they use molex so i replace them with some sharkoons instead. Now i have a bag full of them
It is nice how they have the speed controller cable, and there is noticeable difference in airflow/noise in each low/medium/high setting.
