- 28 Nov 2009
- Manchester
Hi guys,
I hace a 140mm antec tricool, one that comes standard with my case, would like to make it so that it can run lower than its lowest setting, however it just runs off to a molex, black and red wire. There is a separate switch that does high med and low, but low just isnt low enough, it vibrates the case lid and I like things quiet.
If I took a spare male 3 pin fan connector, snipped them both and joined up the black and red wires with electrical tape, would it work ok?
I could then adjust the power from my mother board.
Or is there anther way for me to shave another 20% or so off the fans rpm?
