Antec true 430p
23 Aug 2003
Plymouth
As heading just went up in smoke and a large bang, started to look for replacment but as normalthings have changed and that one is no longer made so what one to use?
Would kep with Antec as good reports on them, though mine went after 3+ years of long running times.
What would anyone suggest, also as the tower is well loaded think will go up a bit say 500watt.
What do you think?
Does it need to be silent or quiet?
If the 430w powered that pc ok then i see no reason to get a more powerful one, unless you are thinking of upgrading in the near future?
