- 28 Dec 2009
- Wales
Quick query regards the above PSU that I must say is absolutely fantastic as follows:
the psu has a 4 pin pwm cable for active fan control. I've not been using this but would I notice much difference in noise if I used it? I assume without it the psu is still rgeulating fan speed or the fan would be at 100 % (though it might well be I can't tell - its not that loud anyway).
Also, I only have 1 4 pin header, the cpu one, could I connect it to the mobo on a 3 pin header? Or use a splitter cable on the cpu header, which is best?
