antec twelve hundred and 2 question?
Status
Not open for further replies.
i've got one, if one of the fans need replacing from the front of the case, would any 12cm fan fit or would i need to try find the exact same fan?
any 12cm fan can go...but remember the ones already fitted are wired to the front meaning you need to remove the wires that go from the fan to the fan controller...
could you splice the wires? ie cut the original wire remove old fan, wire up new fan, and simply tape them together?
also are there any fans on the market that mimic the 1200 oem fans?
Status
