Antec Twelve Hundred question.
13 Jul 2008
Wales
Does anyone have this case with a Tagan TG800-BZ PSU installed? One review mentioned the power lead to the motherboard was short and so bottom mounting a PSU could be an issue. Havent seen this mentioned in any other reviews so was wondering if anyone had this combination with no problems :)
Cheers
I have a corsair psu and that had problems with the 8pin power lead, i could either drag it straight to the socket right across the motherboard, or get a lead extender so i could route it. You can easily buy power lead extenders that add an extra 20-30cm. Theres so much space behind the motherboard on the antec1200 you can easily fit fat cables behind it.
