**Antec Veris Multimedia Stations **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Antec Veris Multimedia Station Basic - Retail @ £22.99 inc VAT *** ***
The Multimedia Station family is a complete solution for home theater PC builders: a stylish IR receiver, a remote control and iMEDIAN HD by iMON software for media management and playback. With four distinct models available, the Multimedia Station can fit the needs of all builders, while the included MEDIAN HD software allows supports full 1080p resolution and is compatible with Windows MCE and all versions of Vista and XP. The Multimedia Station provides all the hardware and software you need to turn your PC into an entertainment center, in an easy to use, easy to install package.
- IR receiver can be powered on the remote or by preset power schedule
- IR receiver mounts in external 3.5" drive bay
- Petite and useful remote allows user to control, play and manage all media, browse data, and change settings
- IMEDIAN software allows the playback of most media formats through internal codecs, full 1080p HD support, and a simple and convenient graphical interface
- Support for CD/DVD, removable storage, network media, and digital/TV analog cards
- Fully compatible with all versions of Windows XP and Vista
Only £22.99 inc VAT.
ORDER NOW
*** *** Antec Veris Multimedia Station Elite - Retail @ £49.99 inc VAT *** ***
- IR receiver with VFD display to see system information, adjust the volume, check email status, and more
- IR receiver mounts in external 5.25" drive bay
- Sleek remote with incredible functionality, allowing user to play and manage media, change settings, and browse via the easy-to-use Thumb Pad Mouse controller
Only £49.99 inc VAT.
ORDER NOW
*** *** Antec Veris Multimedia Station Premiere - Retail @ £69.99 inc VAT *** ***
- IR receiver with LCD display to see system information, adjust the volume, check email status, and more
Only £69.99 inc VAT.
ORDER NOW
I have owned this product before (the dual slot premiere version) and i have to say i resold it within a week. its not too bad feature-wise, but the remote control was very weak and would not work much further away than 1 meter.
maybe i just got a bad one but its something to be aware of.
What is the build quality like?
It looks tacky form the front?
I've been looking at one for my HTPC, however I'd go for the basic because it looks the least naff of the 3 :)
well i cant give an oppinion about the basic one, but the premiere one, this is what i remember (from a year ago mind)...
the display its self is a bit more if a gimmic and not too functional. (but i believe the ones with displays have other extra functions, not just the display.
the knobs fell off a couple of times (i might have been a bit rough) but they went back on just as easily. they were not 100% smooth while turning.
i only used one of the knobs for volume control while gaming, but then i got a keyboard with volume control on it.
i never used the buttons because i had a remote control which had all the functions and more, so no point to that.
i didnt like the way it integrated with my tv card (im using windows xp pro and a hauppauge card - which has a much better remote control anyway)
the software was good overall (lots of control), and the remote control functions were customisable.
there is a forum for the product.
there are updates that u should get for it, those are on the same website.
it looked quite good in my cm690 case, visually very nice IMHO
thats all i can remember but further questions may promt my memory. :)
