Antec VSP-5000
Haha, right well.
There is an SSD bay, above the 4 rail bays.
My ssd does not slot in to it, if it does then it is at an angle due to different heights of the pins within each side of the bay.
4vp8b4pjt
I see what you're saying. Will give it a try when I can.
Thanks for your help, this is my second build in 5 years so still very much a rookie :D
Or does something screw into that side of the ssd and it helps it rest or sit on top of that metal flap?
Then two screws on the side facing inside the case?
do the pins on the right slot into the screw holes on the SSD and you just fix the SSD using the 2 screws on left
