I have been looking for a new case for my mini ITX HTPC project. I would sooo love that Origenae case, but cannot justify spending £350+ on a case currently.
After much hunting and reading I think that I have found a Mini ITX Case that will have good WAF (Wife Acceptance Factor) and suits my needs, It isnt quite the Origenae but neither does it have the price tag
Basically they took the Fusion Case and restyled it for M-ITX.
Features:
Power supply: 150-watt power supply
Silver front bezel
Cooling system: 1 x side 80mm TriCool™ 3-speed exhaust fan
3 drive bays:
- External 1 x 5.25" slim optical bay
- Internal 2 x 2.5" HDD bays
1 half-height expansion slot
Mini-ITX motherboard: 170mm (W) x 170mm (L)
Convenient front ports:
- 2 x USB 2.0
- 1 x eSATA
- Audio (AC'97 and HDA compatible) In and Out
0.8mm cold rolled steel frame for durability
Case dimensions:
- 96mm (H) x 222mm (W) x 328mm (D)
- 3.8" (H) x 8.7" (W) x 12.9" (D)
Packaging dimensions:
- 295mm (H) x 380mm (W) x 195mm (D)
- 11.6" (H) x 15" (W) x 7.7" (D)
Net weight: 5.5 lb / 2.5 kg
Gross weight: 8.3 lb / 3.8 kg
Price point seems to be around £60. I am hoping OcUK are going to stock these
Mushii
Features:
Silver front bezel
3 drive bays:
- 2 x USB 2.0
- 1 x eSATA
Case dimensions:
Mushii
