anti kink coil
Check the last lot of pics in my build log, I opted for one for going cpu to mosfet. Worked out well for keeping the tube loop short while avoiding a kink.
i also have the ek bay res flow and the flow meter does not move i did not know if that was due to bad flow or something you can see the coolant moving in the res though
no you dont, if your patient you can wrap them around the tube. its a bit fiddly i know but you really dont have to take the whole loop apart, do you remember the old notepads that had the metal coil to hold the paper together and you could twist the coil off the paper without tearing it well same principle but in reverse
I just used one in my latest build on a 10cm tube that had to bend 90 degrees. It stopped the tube collapsing at the bend so worked brilliantly for me :)
If you are able to wind the coils on in situ it probably means the tubes are not kinked anyway. You almost certainly wouldn't be able to get one on a tube that was kinked due to a tight bend, without taking that section of tube out so it is unkinked while you put the coil on.
this is my first pc build and computer build so idk really what would be the best way to go at it about taking the tube off because i guess i will have to drain the whole system again here pics of it.
going from cpu to mb
oh and another questions when i turn my pc on. all lights come on for about 2 seconds it turns off again then back on its self and boots upto windows?
If it was me I would turn the rad around so the ports are towards the front of the case. Then I would go pump-cpu-rad-topmosfet-chipset-res-pump. That way you will have a slightly longer tube between the mosfet and chipset, rather than a short tube between mosfet and cpu, thus may be able to get away without a coil on a larger radius. In any event you will have top drain as I see no way of getting a coil on that kinked tube in situ.
