benjo said:You can wear one if it makes you feel better, but i'm sure most people dont bother really. You can always just touch the copper tubing on a radiator though?
I read somewhere that its unlikey for you to fry your components from static electricity nowadays anyway
Hlebio said:Are these a must when building a PC?
And if so, where can I get myself one?
Preferably not online, need to be able to just go out and purchase one..
paulsheff said:The big purple store will have them.
El Grif said:Would want to have jumped up and down in a polyester suit to generate enough static to fry most components excluding the CPU perhaps.
LMAOSiriusB said:Although you may want to remember to undo it before wandering off. Mate said he nearly severed his big toe when he went to answer the door lol![]()
