Anti static
2 Dec 2008
Grimsby
hi guys before i try my first build ive heard about anti static wrist braclets to my parts from not working.
Any advice is welcome :)
Do i need any anti static bracelets ?
dont buy one, you dont need one.
i thought about it too on my first build and now i realise how much of a waste they time they are.
simply touch the side of your case and take care handling things and you will be perfectly fine.
waste of money imo.
I have an antistatic mat+wrist strap. I use it for laying motherboards and circuit boards etc on. and powering it up without a case. But for general use, I tend not to if its inside a case. Just keep it plugged in but Switched off at the wall.
Leave the PSU cable plugged into the back of the PSU, with the PSU switched off at the mains. This keeps the case grounded. Also touching something like a radiator before you start working will be fine.
Unless your going to stand on a nylon carpet while rubbing your hands on a TV screen then rubbing balloons on your head, I can promise you static wont bother you, leave the PSU cable in, plugged into a wall but switched off, sorted.
