Anti Static
14 Aug 2012
Merthyr, Wales, UK
hey guys i have looked on the OCUK website for some anti static equipment for when i do my first build, like wristbands ECT...
I was just wondering if i am a numpty and OCUK do sell anti static stuff. or is the reason i could not find it, because its not there
thanks boss
i will get that then, i will need a toolkit to help me build.
added to my list of things to get on payday
Thanks again.
I've never used an anti static strap and never had a problem, just take the usual precautions and you're fine. :)
You will probably only need a phillips screwdriver for a build.
I've never used an anti-static wrist band before and haven't damaged anything. Just another product there to rake the pennies in. Ground yourself by touching the PSU or anything metal and you will be fine.
Also some cable ties will come in handy ;)
Why try and dissuade someone from using proper ESD precautions if they want to? It’s obviously possible to get away without using a wrist strap, but why not use one?
