antifreeze best way to use it ?
18 Oct 2002
England
Im getting conflicted answers from m8s at work, some say too top it up others say too drain it completly and put it fresh?
Any realy proper answer since im baffeled ?
If the car has not had a coolant change with the manufacturers recommended period (usually between 2 and 5 years), drain out the old and put in the new. If the coolant has been changed within that period and is simply low for whatever reason, then top it up with the correct water/antifreeze mix.
this.
