Caporegime
- 8 Jul 2003
- In a house
Anyone having problems updating this, when i go to update, it just says no valid license file available after the file check, and if i try the manual update after downloading it, it says with the new VDF update kit, the program would no longer be licensed. the file will not be installed.
EDIT: Fixed.
I had to download a new key file and place it in the install folder, but the funny thing is, they say if you update all the time, then the license key will be updated before it runs out, so never does, but mine automatically updates every day, so i guess thats balls.
EDIT: Fixed.
