Just a heads up Antlion have started taking pre orders for the 4.0 version of the ModMic, shipped to UK it comes to around £37
http://www.modmic.com/collections/frontpage
How decent is the cable on the boom pro? Would there be any negative effect on a expensive pair of cans? Looks kinda cheap looking though a really good idea.
http://v-moda.com/boompro-microphone/
it's very good quality that's thy it's expensive it only works with some headphones though it won't work with 558 or 598's for example, it will work with Fidelio X1's though and a lot of people have both on here.
The fidelio X1 is a £299 RRP headphone and they are usually paired together with no negative effects.
looks cheap? you should take a look at other v moda cables then or look through the link above and read reviews on head fi.
the v moda takes a pair of cans like the fidelio X1 and turns them into a gaming headset with only 1 wire you need to deal with (perfect for MIXAMPS).
it's a much better solution than the modmic IMO, if you want a mic like i said just buy a clip on from DX for £1.56
Not exactly ideal for gaming tbh. Plus how would I use that with my console? That's why I prefer mics with a 3.5mm jack so I can use with both my MIXAMP or PC sound card.
Good option for someone starting out making YouTube videos or something though
Ive got the X1's so thats what they would be paired with. Thanks for info will have a think.
It's a very niche market and a pretty novel product. They do have fantastic sound and can be mounted on any headphone - with the V-Modas et al cannot. Admittedly I do use a crappy dx.com mic but its far from great and the ModMic offers vastly beter audio recording, it's main issue its the price (and that is the reason I dont have one!).
It doesnt do a brilliant job, it just about suffices. Yes they can hear you but its pretty damn crap in fairness haha.
I'll need to record myself and play it back on the PS4 again and test it out.
I thought mine was pretty good tbh.
