Any Access Experts (help required!)
10 Mar 2003
Hi,
Basically in my database (personal use) I have some hyperlinks pointing to some documents / exe's, etc.
I wondered if it was possible to put there file size there as well?
It would be useful to see from my point of view.
Thanks,
M.
You can do it using the filesystemobject method in VBA but it gets quite complicated, and could lead to quite an overhead if you have a lot of files.
Dolph - Would not be that bad if you used that VBA method and had it append the file sizes to the database holding the links and ran it on a as and when basis.
True, it depends how dynamic the files in question are and whether they need regular or automatic updating or not.
Well they are pretty static files and would only need to be queried now and again. I'd ideally like a button on the page (something like get sizes) that queried the links on that page and then reported the sizes back into a text box.
If not then a button which updated the entire database would be nice.
Guess I'll have to look into VB scripting.
M.
