Hi,
I always find this part of the forums very interesting and extremely useful so I thought I would post my first question so please be gentle if I have not put it in the right way etc.
Anyway I am in the process of building a replacement pc for my dad who will be using it mainly for his photography. He currently uses Photoshop Elements to alter/amend his raw images, scans negatives onto it and soon he will be using it to edit (basic editing) HD video.
At the moment he is using a 3 year old ASRock motherboard and an E4400 which I overclocked to 2.6ghz together with 3gb of RAM and a 750Gb drive.
I will be putting Windows 7 (32-bit most probably unless Photoshop Elements will definitely run on 64-bit) onto the new pc with his old pc still using XP just so he can get used to the new Windows 7 gui.
I have my old E6600 (which I had overclocked to 3.15ghz for 3 years) spare and am wondering whether this, together with a newer motherboard would provide a substantial improvement from his E4400.
Alternatively I am wondering whether an E5300, overclocked, would provide a better level of performance?
I am thinking that perhaps the E6600 at 3ghz would be similar in performance to the overclocked E5300 but am not sure.
The maximum cost for motherboard and cpu would be around £120 so would still be looking at Core 2 Duo architecture.
Am also aware that perhaps an SSD or a RAID10 type drive setup may assist with his image processing but budget will not stretch to that and I already have a 1Tb Samsung F3 drive ready to go. Also hoping the newer motherboard would provide better/more stable IO than the much older and cheaper ASRock mb.
Any advice welcome and appreciated.
Forgot to say - sorry for the really long post and thanks for reading!
Thanks
si_
Thanks
si_
