Any apps that show or test network speed?
17 Dec 2004
Im going to be sorting out a office network out tomorrow, and was wondering is their a good tool for win xp that shows me the speed of the network when copying files across?
If its a test of raw network speed, then moving files about isn't great.
iperf.exe
You need to put this onto a client and a remote machine, one runs a as a server
Code:
iperf -p 444 -s
where -p is the TCP listening port (use one that isn't currently inuse and that is allowed through firewalls etc...)
Then on the client
Code:
iperf -p 444 -c Servername -w2m
where -c is the target server, either IP or DNS name etc... and where -w 2m is the window size.
I think there's a gui version available but command line is simple enough...
Task Manager doesn't really test network speeds :/ The new Resource Monitor can show how much bandwidth is currently being used but that isn't testing the speed.
iperf or it's slightly more user friendly cousin with a gui jperf is good.
One way to test speed reliably is create a network share on one machine
Then on another machine, install TeraCopy and copy a large file (1gig ish) to the network share using TeraCopy
Will tell you the speed it's copying
Of course it will be limited to harddrive speed / network speed
