22 Feb 2021 at 16:25 #1 swooph swooph Associate Joined 13 Nov 2017 Posts 24 i guess the question is in the title! Are they B550 Motherboards with wifi and minimum 8 x SATA?
22 Feb 2021 at 16:42 #2 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 18,764 Location West Side ASRock B550 TAICHI
22 Feb 2021 at 17:53 #3 orbitalwalsh orbitalwalsh Soldato Joined 1 Dec 2015 Posts 18,512 mickyflinn said: ASRock B550 TAICHI Click to expand... Check lanes to see if any m.2 removes it or using any USB C ports internal or external. X470 or x570 personally if your after a lot of SATA ports
22 Feb 2021 at 20:02 #4 swooph swooph Associate OP Joined 13 Nov 2017 Posts 24 orbitalwalsh said: Check lanes to see if any m.2 removes it or using any USB C ports internal or external. X470 or x570 personally if your after a lot of SATA ports Click to expand... Good call. Do the x570's take a 3900XT?
23 Feb 2021 at 02:52 #5 Dg834man Dg834man Associate Joined 2 Sep 2016 Posts 1,111 swooph said: Do the x570's take a 3900XT? Click to expand... yes x570 will run most things
28 Feb 2021 at 07:24 #6 pc-guy pc-guy Soldato Joined 29 May 2005 Posts 5,011 X570 is your answer. ASUS STRIX X570-F Asrock X570 PG Velocita ASrock X570 Thaichi ASUS STRIX X570-E Asrock X570 EXTREME4 these are the boards with 8 SATA ports some comes with wifi and some don't Last edited: 28 Feb 2021
