So would you say that was about right for a iPhone 6 ? Charge my phone before I go to bed then is beside me all night before I start using it next morning.
It's similar to mine, which took a couple of days to settle down. There seems to be a lot of background processing for spotlight etc that takes place in the first couple of days if you restore from a backup.
Then again YMMV, as it depends on the signal strength in your area. Low signal strength causes the phone to put more power into the radio draining the battery quicker.
Screenshot? Try Dropbox, upload it to the public folder and copy the link.
If you use iMessage and Face Time, you can save the radio system from wasting the battery search for 3G/4G service by enabling Airplane Mode and then re-enabling WiFi as this turns off the cellular radio system.
Set call forwarding to desk/home phone too if possible.
