any decent wireless headphones ?
5 Jan 2005
Engerland :)
at present im using some Sony MDR V700 headphones...from when I tried a bit of Djing....... the problem is they get real hot .. and I find them uncomfortable.
Was thinking of maybe some wireless for watching movies and games...
anything good ?
or stick to wired.... and care to recommend some.
cheers
I've tried the sennheiser RS140's I found them to be pretty good to be honest, I'd compare the SQ to be similar to my old HD465's. Slightly light on the bass, but still very good. One annoying thing about them is that if there is no imput for a while then they search for signal = loud beeping etc. But depends what you're using them for, if you can get away with wired then that'll definitely be the best bet.
However I do recommend you avoid the RS120's, I've not personally used them but many reviews of them don't look favourably on them
i'm in the process of selling my sennhieser rs120's and i'd never go back to radio frequency wireless headphones far too much interferance
no sense of silence... constant buzzing got so fed up with them
I always loved wireless cans... but for true sound quality it just wont come anyware close to a decent pair of wired headphones.
After like 10 years of using wireless headphones and then listening to my 1st decent Wired headphones around £100-150 price range I was extremely disapointed..... because I missed out so much information ! so all my films/tv shows and favorite artist will need to be relistened again !
