any difference?
26 Jan 2006
Is there any difference if you run higher FSB and lower Multi or higher multi with lower FSB for the same or similar final clock?
I am trying to find my max FSB and so far 280 with 1.4v chipset seems stable, so I should just start with multi of keep pushing up to the highest possible multi?
An overclock done by raising FSB will give you better perforamnce than one done using simply a multiplier raise.
