I really don't understand how anyone can learn to DJ "properly" without experiencing vinyl.
Using vinyl you will get a better feel of what you are doing/meant to be doing. Its tough and you'll learn more than just using some PC software which can beatmatch for you, completely takes away a lot of the skill.
Get some cheap 2nd decks and a mixer buy a few vinyl (get 2 of the same copy) and learn to beat match and drop the tunes in and get a feel for what you're doing. Then you can experiment with other means.
Buy 2nd hand denon twin cd deck
Buy 2nd hand mixer
Profit!
If you're looking for work, you'll be surprised how many places don't even have turntables anymore. Good cd decks have been around for over a decade now, they're just as tricky as vinyl, but you can't you won't hear the scratches and you can't lift the wrong needle during a show![]()
I'd suggest not buying those, they are terrible![]()
i think youd struggle to find good venues without turntables. especially since things like tracktor scratch and serato are becoming very very popular amongst the big name djs. which a few of stillof still play mainly vinyl anyway
and as for not lifting the wrong needle. pressing the wrong eject/stop button...
Really? Why?
Out of the last 7 venues i worked at, a total of none of them had any vinyl facilities.
The eject button doesn't work when the disc is playing ....
