Any DrayTek Vigor 2860/N-Plus owners?
Man of Honour
20 Sep 2006
I've got mine arriving today. Just wondering if there's any owners on here who could share any hints/tips? Quite looking forward to having a play, I've wanted one for a fair while.
I have the 2860Vac, quite an impressive feature set although I've encountered two bugs.
1) The VDSL2 connection seems to have an INP of 1.5 and a delay of 8ms on the downstream and the router's causing that (no idea why)
2) The UPnP option, when enabled with connection control, causes the router to regularly crash with my multiple public static IPv4 address allocation
Use the vector 2 modem code, it's better for just about everything, I'm on adsl2+ and it's better
On 5GHz, don't pick channels 120, 124 or 128, unless you want to wait 10 minutes for it to do dfs checking.
ixel: the connection control bit of upnp should be unnecessary though? best to just turn on upnp and leave that option disabled. Also vector 2 modem code might help with your first problem.
If the firewall is on, the internet is sluggish and hardly loads. What do people set theirs to? And what MTU size should I use?
Thanks. Tried just enabling UPnP on its own but unfortunately it crashed (reboot cycle), though it took longer to crash. The only thing so far that's effected by having UPnP disabled is GTA V Online (PC), when quick restarting a mission it will timeout.
Regarding the modem code, I am using vector 2 unfortunately. Could my firmware perhaps need reinstalling from scratch with a factory reset?
turn off hardware acceleration, it causes some people a lot of issues at the moment, it's set to Auto by default
changing the modem code shouldn't require a factory reset or anything
Done the firmware upgrade. Are you positive it's hardware acceleration? As when I turn off the firewall everything is perfect. Also read about MTU tuning.
I also turned off hardware NAT acceleration virtually since day one as I read some issues about it on another forum somewhere.
Regarding my crashes, I have discovered an interesting command which might be pointing me in the direction of the cause:
Code:
> sys ver dbg
Router Model: Vigor2860Vac    Version: 3.8.1_RC1 English
Profile version: 3.0.0    Status: 1 (0x4a0e5f76)
Router IP: 192.168.1.1    Netmask: 255.255.255.0
Firmware Build Date/Time: Apr  2 2015 11:54:15
Router Name: DrayTek
Revision: 48134 drayos2015
Current VDSL2 Firmware Version: 05-07-04-03-00-07
ADSL Firmware Version: 05-07-01-08-00-01 Annex A
---------firmware exception debug info-----------------------------
 EPC=80043020, Cause=80800010, Status=be100000, BadAddr=827c7364, RetAddr=80026f3c
 exception id=4(ADEL: Address error Load)
 exception occured in IdleTask Timeout
[b] task_id=127, SP=0x827b3b88(4224 bytes free, 1520 used bytes),[IPv6_Task][/b]
 system tick =11617068
 CURRENT_VERSION : 3.8.1_RC1
 get from address : 80004000
 Dump CPU registers:
 $ 0: 00000000 fffffffe 00000010 00101000
 $ 4: be100000 00000007 00000008 00000078
 $ 8: 80d632ae 00000000 00000000 20686170
 $12: 0000000f 827b39a8 80b61088 ffffffff
 $16: 00000061 83714d00 80d632b7 827b3c50
 $20: 00000000 d1b71759 10624dd3 51eb851f
 $24: 00000000 80792f20 00000000 00000000
 $28: 00000000 827b3b88 000186a0 80026f3c
List a possible caller functions:
 func( 0)=80026f3c
 func( 1)=80792f20
 func( 2)=80d632b7
 func( 3)=80b61088
 func( 4)=80d632ae
 func( 5)=807ad4e8
 func( 6)=80d632af
 func( 7)=80025764
 func( 8)=80d632d3
 func( 9)=80025d40
 func(10)=80d63238
 func(11)=80896230
 func(12)=80d63280
 func(13)=807bb7d8
 func(14)=80d63280
 func(15)=807b3438
 func(16)=807b34d4
 func(17)=807b34b0
 func(18)=807b6b00
 func(19)=80025704
List backtrace functions:
 func( 0)=1100fc03
IPv6 maybe? I am using IPv6, so perhaps I should try disabling it and seeing what happens from then on. I still have no idea regarding the INP/delay anomaly I have, but I might try factory resetting and setting everything up again.
I've owned a 2860n for over 18 months, using it with PlusNet. Regardless of firmware version noticed no performance issues with firewall.
I'm using 3.7.8.3 Vector 2 firmware.
I don't use hardware acceleration as it disabled QOS rules and I have QOS rules setup.
Always used MTU of 1492.
It's definitely the Firewall for me. Whenever any of these are enabled it's like being on dial up.
I really liked ours but due to being on a really poor line and the Drayteks err'ing on the side of stability on the line speeds had to replace it with a Billion so I could tweak the SNR to give us a hefty percentage increase in speed.
Did see with one of the updates they introduced a feature to modify the SNR but didn't seem to actually work or do anything so back to the Billion for now :(
S2KIP, do you have any custom rules in your firewall filter setup?
The only ones I have are the default xNetBios -> DNS rules for voice and data.
The firewall page you posted is what I have, other then firewall voice and data enabled.
No rules at all. All I've done is configured wireless and WAN, everything else is as it came out of the box.
My DOS defense has always been off. I mentioned it before in case it was on and causing a slow down in the firewall.
I did a quick google on Draytek firewalls slowing internet, there is a few posts about it but nothing conclusive to what causes it.
When firewall is on what is the routers CPU usage status? Is it running under high load.
No, everything looks normal. I might get wireshark on the go to see what's actually happening. It's almost like there's an MTU issue but that's always been left unchanged. I've put a post on the Draytek forum so I'll see if I get a reply, if not I'll log a support ticket.
