Any dx11 cards same size as a 4890?
5 Jul 2009
My 4890 just about fits inside ( sideways) my case before it starts to go under the front frame and have seen some of the new dx11 cards are rather long so was wondering if any are the same size as a 4890
thanks
The XFX 5850 has the power connectors on the end of the card as well instead of on the top, so this will make it slightly longer.
you sure?
i haven't measured because ive just shipped my 4890,(and im not ghay) but the 4890 seemed shorter.
Whether you are homosexual or not is irrelevant. It depends slightly on the 'brand', but I think all 4890s and 5850s are supposed to be in the 9-9.5 inch range.
