Heyas all, just working with a Teacher at work on an excel file that has some stuff in that I'm not 100% sure on, its to do with child behaviour levels,ie if you go to a certain kid's row, type in PE as they misbehaved in PE it clours the box yellow (no text) and gives a PE flyover when you hover over it, thats all good and well, he has programmed the macro so that all functions correctly.
The problem is, he wants when you fill in a box, it will also create/update a graph on a certain sheet (Create if not present, update if one is present) (one extra sheet per student in the file) I realy have no clue where to start on this, not sure how it'd work or if it even would, just to get some data on the bar graph such as 1 x pe 2 x re etc..just to try and get something started, as I'm realy not sure on a good place to start.
Any ideas would be welcomed!
Thanks!
-T
Thanks!
-T
