Dear all,
I need to run 25m of network cable internally around my house, so I am thinking of getting the 30m OCUK value CAT5e cable (http://www.overclockers.co.uk/showproduct.php?prodid=CB-038-OK&tool=3). I've done some reading around the quality of network cabling that is sold in various places and am a little concerned about some of the quality issues that are being reported on reviews of other cables.
Therefore, has anyone got any first hand experience of using the 'value' branded cables and has any extra info about them (e.g. are they twisted/shielded etc.) before I pull the trigger and order one as I am a little concerned about the 'value' tag as I don't mid paying more to ensure that I get a quality product that will do the job.
The cable will be used to connect two switches in my home that are, in turn, connected to GB ports and will be used for data transfers, so speed + reliability are my primary concerns.
If these aren't the cables I should go for, what are the key features that I should look for when buying?
Thanks for the help
Thanks for the help
