Any good System Spec & Monitoring software ? NZXT alternative
29 Dec 2012
Any good System Spec & Monitoring software and what to use ?
I've been using a number of software's but they all have some limitations
CPUz - simple easy to find the main hardware information
Hwinfo - simple has detail on most of the hardware inc brand
Speccy - like the above simple detailed on most hard the only issue I had was finding finding the brand and model - example GPU (Powercolor RX 580 Red Devil/Dragon) Ram Team group
NZXT Cam - Has monitoring dashboard, Looks good, easy to use and find what im looking for but is not as detail, again had some issues with brand and model like the above, found ram not the GPU), has some extra bloat
CPUID - very detailed but cane confusing and can miss models
I Would like something that looks nice but also give good details
I've been using a few monitoring software cpuz, speccy
What limitations do you have with HWiNFO64? That's my current favourite, and I haven't found any issues with it. Even have it hooked up to Rainmeter so I can easily glance at usage/temps/speed/etc on the desktop.
Yes you are right it is the best ive found out of all the software ive tried for infomation
The only issues I have are the UI and the number of windows need to get all the info, I would like a more modern cleaner look like NZXT.
Open HWINFO but tick only show sensors, you'll get everything in one list that way.
