any help 360 wont conect to pc?
6 Oct 2007
Liverpool
i have had it working in the past... through my linksys.
av done nothing but reconnect my linksys and it will not connect i've tried reconnecting using a fresh 8digit code and cancelling the connect it had and unistalling the extender on my pc and tring again nothing seems to work....
..it stops wen the pc gets to 'config ya extender'
and the xbox says conecting and then an error comes on the pc.
I know they can see eachother.
after running a test it fails on a selected PC
Any help this is anoying.
Many thanks
