- 1 Mar 2019
So I was playing the battlefield 6 beta, I went to update my corsair Icue drivers in the background and the whole system blue screened and it seemed to have corrupted windows. Sometimes it would load back up sometimes it would just blue screen again.
Tried doing a repair using a USB boot drive with a windows installer on. Didn't work. Whenever I would get back in to windows the stuttering would be unbearable. I have 4 Nvme ssds so I was able to get majority of the important data off of the C drive before it seems to have gone kaput. Can't see it in bios now or if I go to do a fresh install. I tried a fresh install using a partition on one of my other drives, but within minutes it started behaving exactly the same way, constant freezing and micro stutter even at idle.
My system is a custom build, 14900k, z690 Aorus Xtreme board, 96gb Gskill TridentZ 6400 CL 32, RTX 5090, 9x corsair QX120 fans. Any ideas, I've troubleshooted a lot and have been tearing my hair out. Its so bad the system is practically unusable. Minded just to do a CPU motherboard upgrade to AMD, been thinking about it anyway.
