Any help would be appericated
23 Nov 2011
I purchased a Crosshair IV Extreme Amd motherboard running a AMD Phenom II X6 Six Core 1100T Black Edition 3.30GHz
Gainward GeForce GTX 580 "Phantom" 1536MB
heres where the problem arises i also purchased,Corsair Dominator GT 6GB (3x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel Kit (CMT6GX3M3A2000C8) [CMT6GX3M3A2000C8] not really understanding the differance between dual channel and tri channel memory,after reading these fourms i now get im running tri channel in a dual channel board
My question is this, is my memory running 1 set dual and one single or 3 single.also could i buy another stick of the above memory to make it 8gig dual,this would be an expensive option as this memory is £140 or can you get a single stick of the same anywhere.
Or cut my losses and buy 8gig dual from OC's
All of the above was bought from OC's UK
If i have to cut my losses and get a new set of dual memory any recommendations would be great,the rig is for Gaming mainly and web browsing
How long have you had the RAM?
If you've had it less than 7 working days, and you had it delivered, you can return it using the Distance Selling Regulations for a full refund.
The Memory tab in CPU-Z should show you in what mode your RAM is currently operating but having 3 sticks might confuse the reading.
Ive had it for a good 4/5 months,CPU-Z says its dual but like you said it might be confusing.
Was a silly mistake on my behalf but you live and learn i suppose,the machine runs fine,but if im not getting the most out of it id like to be able to fix the problem
Performance wise it's probably not going to make a massive difference running 3 sticks instead of 2/4.
Try it.
Play/benchmark one of your games with 3 sticks and then do the same taking one stick out leaving a dual channel pair.
Going from 6GB to 4GB might make a bit of a difference but hopefully you'll see that performance in both configurations is acceptable.
Ultimately if you're not happy running 3 sticks then you take one out leaving 4GB, try and source another singe stick or start again.
Thanks for the advice will give it a try,failing that is there a single 2gig stick of my memory avaible it dosn't have to be same brand just something that will work to make up the full 8gig
All your RAM has to run at the same speed, timings and voltage so ideally you need a stick with the same settings as your current RAM.
You can always buy a stick with, say, a lower speed but you'll either have to try to overclock it to the speed of your current RAM or you'll have to down clock your current RAM to match.
