18 Mar 2010 at 01:10 #1 enigma27 enigma27 Associate Joined 3 Jun 2007 Posts 2,287 Location Essex Hi All. CPU-Z and core temp seem to be reporting my CPU att he wrong values.. any ideas why this might be? underneath you can see windows reports it at 3 gig ( Multiplier x10 / FSB 300 )
18 Mar 2010 at 01:35 #2 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,083 You have SpeedStep enabled which dynamically changes the processor's speed to save power. It isn’t a problem if your machine is stable. This question gets asked fairly regularly so a quick search should fill in the details.
18 Mar 2010 at 02:27 #3 Jotunkaiser Jotunkaiser Associate Joined 17 Apr 2009 Posts 303 Location Liverpool you can just turn it off in your bios, so your cpu runs @ the right speed -all- the time instead of just when needed - upto you though.
18 Mar 2010 at 06:52 #4 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Your FSB is higher than the default speed which should be 266mhz, so your overclocking the cpu which is not going to course any problems. See my thread below regards speedstep http://forums.overclockers.co.uk/showthread.php?t=17972811
18 Mar 2010 at 16:33 #5 enigma27 enigma27 Associate OP Joined 3 Jun 2007 Posts 2,287 Location Essex Thanks Guys. Didnt even realise I had it turned on... I would have searched but then i would have put you lot out of a job
