PC spec as below, running Win XP SP2.
I'm getting occasional crashes with my PC, symptoms of which described below.
Usually starts with the mouse cursor sticking or "jittering" across the desktop or application. If I'm running a game with sound, the sound (and graphics) will momentarily stick or freeze. Eventually if I don't close down the programmes and reboot or shut down, the PC does a BSOD (haven't got the error message unfortunately).
Have noticed it tends to occur after using IE7 though not necessarily exclusively so.
All mobo drivers, graphics drivers etc. up to date. Don't think it's a GFX card issue as it did it when I had my old 7600 card in the box and still does it with the 8800 installed.
