I do images in Illustrator 5.1, which I use on a cutting machine that uses DXF files, problem is illustrator exports at different sizes to what is in the ai file, so atm I have to save as .ai then use Corel Draw to save it as DXF.
I would love to cut out using Corel Draw for this, has anyone got any ideas how I can get illustrator to export to DXF at the right dimensions/scale?
