Any improvements?
15 Feb 2008
Thinking of upgrade my cpu mobo ect. My pc is used for photoshop, video encoding & gaming.
Anything below that may be worth changing?
MSI X99A SLI Krait Edition
Intel i7 5820k
Corsair Vengeance LPX 16GB 3000MHz
thanks.
Looks good only thing I would suggest is more ssd space for the encoding but otherwise good choices.
I plan on buying an m2 ssd later on so my current SSD will be used for encoding.
Memory is DDR4, 4x4GB, yes? Just checking.
Good spot, just swapped over for the quad channel kit.
Do you really need it though or is it just a upgrade itch? A 2600k at 4.8Ghz is still a extremely capable cpu.
I only upgrade every 5 or 6 years and i have had my 2600k since launch.
My reason for upgrading is my current system will randomly crash after/during gaming (have a thread in the gfx section) have tested all parts but no fault found so only parts left to replace are the above and PSU.
