Any issues with this selection of components?
6 Nov 2017
Hi,
Looking for a new PC and think this will do the job, This will be used for programming, 3D Cad, 3d printing, Video editing etc - In not much of a game player so its not for that.
Thanks
2 MO-062-AS Asus VX279Q 27" 1920x1080 IPS Widescreen Super-Slim Bezel LED Monitor - Black £229.99 £459.98
1 BU-0A8-OG DEFCON 1C - Asus ROG Maximus X Hero - 8700K @ 4.80GHz Overclocked Bundle £1119.95 £1119.95
MY-459-CS Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK32GX4M2B3
BU-09W-TL Asetek 570LX 240mm High Performance CPU Cooler - 115X
1 CA-045-SF Super Flower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - White £132.95 £132.95
1 HD-22H-SA Samsung 960 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive £248.99 £248.99
2 CA-172-NX NZXT H440 New 2015 Edition Case - Matte Black £114.95 £229.90
1 GX-10R-ZT Zotac GeForce GTX 1070 Mini 8192MB GDDR5 PCI-Express Graphics Card (ZT-P10700G-10M) £398.99 £398.99
£2590.76
Built a system base don Ryzen 1700 and GTX 1090 for a friend that does CAD, 3d work and 3d printing. Went with Ryzen 8 core/16 threads for CAD work that uses CPU for rendering as the more cores the better! overclocked to help a little as well
gtx 1080 along with GDDR5X for any rendering done off the GPU- Ti is almost same power but when RENDERING you'll see the gains with GDD5X , And i got the 11Gbps version for him which overclocked to 11.8Gbps! flies
price of coffeelake at the moment, worth looking in to X299 system, were Quad channel ram can help- slapping a 8700K version screams gamer, 8700 non K would have done the trick with a basic £120 pound board - the board you selected is a Gamer and Overclockers Boner!
Thanks - the one thought about the high spec is the assumption that it will last me 5 or more years before I need to think about upgrading again - not sure if that logic works
in reality is should last you a long time, but if something can do it slightly cheaper- better and has a better option to upgrade, its worth the look into.
the Ryzen Chip socket is good for another 2 generations, AMD in 2 years time might release a mainstream 12 core design which would be awesome for cad rendering- at the moment its on their High end systems and expensive, In a few years time you could pick up on of those second hand etc etc , but who knows what amd will do.
also the 8 Core would last you longer for cad then 6 core ryzen .
do you do rendering at all ?
