Any issues?
8 Aug 2008
I've got a really old machine I use to test sites I've built on IE6. It really struggles so I managed to get my hands on some more. The RAM itself is a lot taller but SDRAM that's PC133 which is what it was originally. Here's the CPU-Z output:
Before:
Code:
Memory SPD
DIMM #1
General
Memory type		SDRAM
Manufacturer (ID)	NEC (1000000000000000)
Size			64 MBytes
Max bandwidth		PC133 (133 MHz)
Part number		458CB647PFA-A75
Serial number		3F01C512
Attributes
Number of banks		1
Data width		64 bits
Correction		None
Registered		no
Buffered		no
EPP			no
XMP			no
Timings table
Frequency (MHz)		100	133
CAS#			2.0	3.0
RAS# to CAS# delay	2	3
RAS# Precharge		2	3
TRAS			5	6
After:
Code:
Memory SPD
DIMM #1
General
Memory type		SDRAM
Manufacturer (ID)	Micron Technology (2CFFFFFFFFFFFFFF)
Size			128 MBytes
Part number		8LSDT1664AG-133E1
Serial number		200F4E3E
Manufacturing date	Week 22/Year 01
Attributes
Number of banks		1
Data width		64 bits
Correction		None
Registered		no
Buffered		no
EPP			no
XMP			no
Timings table
CAS#			2.0	3.0
RAS# Precharge		2	3
TRAS			5	6
DIMM #2
General
Memory type		SDRAM
Size			128 MBytes
Serial number		200F4E0A
Attributes
Number of banks		1
Data width		64 bits
Correction		None
Registered		no
Buffered		no
EPP			no
XMP			no
Timings table
CAS#			2.0	3.0
RAS# Precharge		2	3
TRAS			5	6
It did do a weird grey screen when I was in windows after the inital boot, which switched to a blue screen system is busy, but after another restart it seems to be working ok and everything that was mind numblingly slow before or failed completely seems to be a lot better.
