Hi,
Hopefully someone can help with this,
The front door to my house is a steel front & backed timber frame with a Euro Cylinder lock. The door can be opened from both the inside & outside unless it is either locked with the thumbturn (inside) or via a key (outside).
My lodgers do occasionally forget to lock the door behind them when they come in and this morning when I left for work the door had been unlocked all night. Now I don’t barricade myself in my own home but should a ‘chancer’ pass by and try the door I’d be a little more than annoyed if they can just walk in off the street.
Lifting the handle upwards engages a few hooks & bolts but unless the lock is turned pushing the handle down withdraws them.
Does anybody know what the suitable mechanism I require is called? I would like the door to function like a normal UPVC door in that without a key you cannot gain access from the outside, so should the door be pushed to and shut, it is secure.
Thanks,
BennyC
Thanks,
BennyC
